Gira HS and 2 Byte float?
    Hello Guys..
    I have a Basalte Auro Motion detector, which can broadcast LUX value from the room, this is done in 2 Byte Float like - ETS sees it as data type "9.004 LUX".
    But i can't get the HS to read that type of data.... It only says 0 - anyone has a solution for that?
    Can you read it with ETS?
      Yes i can... When going into "Read/Write" mode - i ETS sees it as 9.004 LUX....
      I also get a value etc. 5 lux from ets
        Which Data Type do you use in the HomeServer?
        16bit EIS5 oder EIS10?
