Hey
Gira and Siemens has bus couplers (BTM - Bus Transceiver Module) for devises where the application resides in the device it self. As I understand it all functionality under level 5 in the ISO model is implemented I the BTMs, while the rest lays in the connected device That would ideally make them independed between manufacture. Is I then possible to use a Gira pushbutton with a Siemens BTM?
The reason I am asking is that I want to use Siemens combined unit UP 525 (Dimmer/BTM) together with Gira pushbuttons.
