I've a Hager Univers electric cabinet
So far, I've used solid wire 2,5² for the internal wiring. As the supply is 3 phases, I've used a color for each phase.
Now I hear that flexible wire 2,5² is more suited, mainly for heat dissipation. This argument makes sense, plus the flexible wire is much more comfortable and easy to install.
Which type of wire is recommended for the internal wiring of the UV ? solid vs flexible ?
I guess it has more to do with "good practices" than regulations.
Thank you for your advice
