FeedBack form bus updating Q-Client
    Q-Client FeedBack form bus updating Q-Client
    Hello,
    I have a problem with getting feedback through Gira softwares (HS Expert & QuadClient). If I understood correctly, I have to use the one main communication object, and two sub-elements of HS Expert, from the Objects imported from ETS.
    Here is what I would like to achieve :
    1. Objective :
    Be able to have my iPhone GIRA application with correct values of diming % for my entry lamp. Should I start the GIRA program, or change value of the lamp from wall buttons.
    Here is what I have :
    2. ETS configured addresses :
    a. 1/1/2 : Sending value on the KNX bus over this address SETS that value to the lamp, for example if I send 70%, the lamp is at 70% of brightness.
    b. 1/1/3 : FeedBack value address where I can see the actual 70%. Sent from the ABB element, and can be gotten as well by a read demand on this address.
    Here what is imported :
    3. HS Expert importation : All above plus many other addresses, in “Communication Objects”
    What I suppose :
    4. Playing around with :
    a. One main address Object, I suppose the one feeding the bus with the message  1/1/2.
    b. Two kind of sub-objects of this main one could be used in HS Expert (those are the one I don’t understand how to use) :
    i. Watch address
    ii. Central address (Listening)
    I’m very sorry but all I tried resulted in a big failure… Can anyone help me?
    With all my wishes for Xmas and Year 2015,
    Daric
    Hello again,
    So I suppose this forum is not able to help with those specific questions... Sorry...
    Where should I ask?
    If ever anyone could take 1 minute to direct me...
    Regards,
    Daric
      Call Gira Hotline
      Tel +49(0)2195-60 20
      Did you set all Flags in the ETS?
      How connected to the HS ? IP Router or USB?
      line coupler? Open in the ETS?
      Henning
        Hello!
        Thanks so much for the answer!!!
        I never thought about even trying to call GIRA hotline... And as you could see I don't speak German good enough for technical discussion...
        1: The flags are untouched in ETS, but as I could see they are set accordingly to the purpose. The fact is that I SEE the messages from the light on the bus, they just don't update my Gira view on my iPad.
        2: I am connected via USB at the moment, but will switch to IP one day, I already have it.
        3: Yes, I opened the line coupler as I could see it was one of the common issues.
        Would you need screen shots of the messages in ETS?
        Merry Christmas, and thanks again...
        Daric
          The
          Gira Hotline is also in Englisch!!!
          Good and helpfull People!
          Call the Hotline from mo till fri from 9.00 - 17.00 and ask for a HS Engineer im English, they have One, you Might wait a few minutes.
          Yes, screenshots from the communication objects in the ets (dimAktor) would be helpful. Make a shot from the hole screen in the topology from the aktor with the communication objects.
          A Screenshot of the QC is helpfull too. Make a Shot from the Dim Funktion. Maybee there is the Problem.
          Then A Screenshot in Expert of the Communikation Objekt from the Dim (1/1/2 and 1/1/3)
          Have you sent and booted new the HS?
          Did you see the telegram on the group monitor in the ets, if you sending the telegram from the iPad?
          By the way, my English also not the best!
          Your welcome
          Henning
          Henning
