Weather station: BMS Quadra
    Hello!
    I have recently installed the "BMS Quadra" weather station, everything works fine except the point that the wind speed and the wind direction always calculates the same. Wind speed shows 35 m/s and wind direction always shows 7FFF. Does anyone else have had this problem, can it be solved or is my weather station just broken?
    Regards. Sloven
    Hi Sloven,
    35 m/s is normally the case when the Quadra is in the so called emergency mode, means the ultrasonic quality isn't valid. So it could be that the quadra is broken or even there are some other reasons for the faulty ultrasonic values.
    My suggestion is to get in contact with the BMS hotline via email or phone. Due to my personal experiences with the hotline I guess they can give you good advices how to continue.
    BR,
    Oliver
