What do I need
    KNX/EIB What do I need
    If I buy this weatherstation "Gira KNX weather station Standard" - Gira KNX weather station Standard
    Can I get the windspeed and temperature directly from that or do I need anything more?
    Yes you can
    All you need is a KNX system.
      Hello..
      everything is possible! :-)
      Best regards
      Peter
        What Matthias wrote is correct you can it but i have the same and i think and i know the Windspeed is not correct!
        When the weather is better, i will check why is it wrong! Perhaps my position not 100% right!
        Best regards
          I have a complete KNX system, but what I ment was if I need another logical module inside or is int enought with Weatherstation as it is
            Everthinig is in the Weatherstation! What your need is ETS Software!
            Best Regards
              Thank you all.
              I was just wundering since I saw this Gira KNX weather station Comfort But it good to know that thats not needed
