Ive a question about HS Visu, camera, dyndns
I found the following, but it's not quite the same problem, no eibport, but LAN with private address 10.0.x.x, ADSL, rtr and switch.
In the Visu, I give acces to the outside world to cameras.
This works fine: either from within the Visu or direct link to
http://warichet.dyndns.org/: port/HS/imagepath. No problem.
But ... from the inside LAN, I'm unable to see the images over the dyndns link. It's quite normal, but I have to rely on someone else to test the setup.
I guess there is a workaround ?
I remember to have seen camera images from forum members, so maybe there is a trick ?
NB: The images are obviously available over the internal IP
http://10.0.1.2xxx/: port/HS/imagepath.
Thank you for any hint.
