neuling braucht hilfe mit HS3
    I already applied for the next HS3 training @ Gira , but I can't wait with playing around.
    I imported some addresses and created a QC page in Experte. Now I would like to display it in my client. I managed to display a normal visu on the web browser and client, and switch a light, but how can I get the nice looking QC appearing on my screen ? Is there some parameter in the Experte to switch between normal visu and QC ?
    Another question: what''s the best way to go if I want to use HS with iPhone ? QC or regular visu ?
    Anybody has experience with iPhone & HS ?
    Many thnx!
    Mike.
    grusse,
    Mike van der Hulst
    Domoticom (NL)
    QC ONLY works with QC-Client, not within any browser.
    QC does not work on iphone.
    My opinion about QC is quite clear, you can read it in many postings .
    My recommendation: start using "normal" visu with Ajax. For Iphone HS includes so called PocketVisu, which bases on Ajax, too.
      If you like to try out Quadclient anyway you can find the setup file in your "Experte" install folder "..\Tools\QuadClient_Setup\"
      Regards
      Martin
        ok, thnx, I already discovered QC doesn't work with a browser, bus my question is: how to get it in the client application ?
        about the iPhone: Gira is advertising with the new layout (QC) everywhere, showing it on the iPhone........is it difficult to get it running ?
        Anybody have a sample project ?
        Thnx,
        Mike.
        grusse,
        Mike van der Hulst
        Domoticom (NL)
          A sample project for Iphone is included (normal Visu, Ajax).
          About the pictures: they look like QC, but they aren't ;-)
            The layout displayed on the iphone is only a "QC"-looklike Visu.
            You can find an example in the sample project that is installed together with the "Experte".
              wow, this forum is very active ;-)
              Thanx a lot, the QC is working, now to go for the real visu ;-)
              I know QC is limited in options. That's wy I use Asterisk (ViOP) without GUI, so if I can be of help with Asterisk integration, shout ;-)
              Mike.
              grusse,
              Mike van der Hulst
              Domoticom (NL)
