HS: status objects vis not updated
    I have a simple KNX system and made a visu, based on the HS demo.
    Ik can switch on/off and dim a dimmer (Hager TXA210a) from HS (client app). But sometimes the on/off and dim values are not updated on the screen.
    If I send a switch or dim command from ETS3, then the dimmer responds with new status values, but in this way, HS nver updates.
    Looks like HS doesn't read the bus at all for staus objects.......
    Anybody have an idea ?
    Thanx,
    Mike.
    grusse,
    Mike van der Hulst
    Domoticom (NL)
    Are you using a line coupler?
    It could be a problem of the filter rules in such a coupler if the ETS-interface is on another line than the HS.
      hi,
      no line coupler, it's a very small demo project laying on my desk ;-)
      I think I just forgot something very basic, but I don't know what......
      HS doesn't handle any telegrams, it only sends them out OK
      Mike.
      grusse,
      Mike van der Hulst
      Domoticom (NL)
        hi,
        I discovered, when I chnge the status of the actor, HS will show it in the client after I refresh (go to another page and back) or when I wait a few minutes........I was expecting the visu to be almost real-time
        Anybody an idea how to tune this ?
        Grusse,
        Mike.
        grusse,
        Mike van der Hulst
        Domoticom (NL)
          Reduce refresh time! I normally use 5 Seconds locally.
          There is also a second trick that may help:
          Under projekt - Refreshzeiten increase Verzögerung Client to 250.
          Use R1!
          Gruß Matthias
          - PN nur für PERSÖNLICHES!
            = problem solved =
            I increased the 'Verzögerung Client' to 250, now it works perfect.
            Thanks a lot Mathias !
            Grusse,
            Mike.
            grusse,
            Mike van der Hulst
            Domoticom (NL)
