How to: hslib
    How to: hslib
    Would someone be so kind to provide some explanation about the hslib, please ?
    I understand I can import a hslib, via Globale Bibliothek, but I'm a bit scared to use it, as I don't understand the implications/consequences nor the way to step back and delete the hslib.
    Thank you
    As you can put quite everythin into the hslib by "globale bibliothek" it is not that easy to explain.
    I guess you have to trust the one who build it a bit, and hope he only put in what belongs in.
    I would advise you to save your projekt bevore importing, because there is no undo functionality.
    "Wer immer tut, was er schon kann, bleibt immer das, was er schon ist." Henry Ford
