Baustein with time function
    Someone has an example of a Baustein with time functions ?
    I checked a couple of Baustein but didn't find it.
    I'm willing to do a compare on certain hours and other conditions in order to take actions, i.e.
    a user click and hour of the day < 12 then do action A
    a user click and hour of the day > 12 and < 16 then do action B
    Thank you
    As far as I remember there should be "Datum und Uhrzeit" which gives you "Ausgang Stunde" in [hours].
    So I would do some logic as follows:
    - Click sets iKO to 1
    - "Eingangsbox" iKO goes into "Und" together with some comparisons as "Stunde < 12" or "Stunde > 8"
    - "Und" goes into "Ausgangsbox"
    Es grüßt der Alex!
      Hi Raymond,
      you will find some examples in the file logic.dat in your HS-directory, e.g. 9043 'Sonnenstand' or 9084 'Sonnenaufgang'.
      Maybe there is a simple 2-module-solution for your problem: you should consider to use the logic module "Vergleicher/Fall-Prüfung (<=) 8 Ausgänge", with the current time as decimal time connected to E1, and output A1 connected to the logic module "Auswahlschalter/Eingang => 16 Ausgänge".
      Gruß, Rainer
