Globale Bibliothek
    Globale Bibliothek
    I would like to share a web abfrage, with all its iKO and Visu symbols, static and dynamic.
    I know it's possible via Globale Bibliothek, but have no clue about how exactly to do it. Also I'm a bit scared to mess up my project with wrong manipulations.
    A little help would be appreciated.
    Also, I've no idea what happens when the thing is imported on a remote computer. Will it be positionned exactly as on mine ? or should we first build a structure to accept the import ?
    Thank you
    Hslib is like a container. Put in what you want, then save it and share it. It will be added to an existing project exactly as it is in your project.
    Actually hslib cannot accept ALL HS parts, for example no sequences. I am full of hope that the upcoming version 2.4 will fix this problem.
      Hi Matthias,
      Thank you for the quick reply
      It worked fine for the Web Abfrage, but for the Visu pages ?
      A right click on a page doesn't show the option "export", nor on the page, nor on the folder
      I missed something ? there is a trick ?
        Mark all elements using CTRL-A, then Right-Click one element.
        The missing feature maybe will be added to 2.4, too.
          Pfiouu !
          Sorry to be a pain, what about the iKO ? are they exported part of the Visu ? or should I do it manually ? (cannot find a way to do it)
          Thank you
            IkOs that are used will be added automatically.
