Gira IP Router: "The Device does not support local programming (BCU version %1)" ??
    KNX/EIB Gira IP Router: "The Device does not support local programming (BCU version %1)" ??
    Hello,
    I wanted to re-program the application of my Gira IP Router (because of the Filter address parameters), when i want to program the application i choose: "Local" in ETS (v3.0f).
    Then it gives me this error message:
    The selected device does not support local programming (BCU version %1).
    I went back to basic and ONLY connected the IP router to the 640mAh power supply and a 24V AC power supply and my network.
    I do NOT press the program button on the IP Router.
    When i choose to connect the Bus via IP router, not via Local, i get the error:
    The individual address is already allocated to the local interface.
    ETS Details:
    EDI: Eibnet/IP
    Params: Name='00-0E-xx-xx-xx-xx';IpAddr='192.168.0.167';Port='3671'
    Last messages:
    21:42:02.836 S 04 P_GETV.req 02 004E
    21:42:02.836 S 06 P_GETV.con 02 004E 09 1A
    21:42:02.899 S 04 P_GETV.req 02 0117
    21:42:02.899 S 06 P_GETV.con 02 0117 11 00
    21:42:17.227 S 04 P_GETV.req 02 004E
    21:42:17.227 S 06 P_GETV.con 02 004E 09 1A
    But that is normal, isn't it ?
    Is there anyone who knows how to program the IP Router parameters ?
    I have tried everything, reseting it to default (Power OFF, press and HOLD the program button for 6 seconds while connecting the Power to it, you see the Program LED blinking).
    anyone ?
    (Or do i need another device like an rs232 or USB gateway to program my IP ROUTER parameters ?)
      I read this sometimes, but I am not sure whether this is corrcet.
        Matthias,
        Can you program the parameters of your IP Router in ETS ? (not by using a different device ?)
        (i heard you have a hell of a basement with stuff there.. .. hope you have the IP Router also.. )
          No, sorry, I never met this device. And I know why
            Ok,, what is your advice ? Buy an USB or RS232 gateway ? (what gira number?) When I order today, i have it monday, so let's try.. I can post the details here.
              First we should ask one of the real professionals around here.
              @Forum
              Wer weiß, ob man zum Einstellen des Gira Routers eine weitere Schnittstelle braucht oder nicht!?
                gelukt?
                  Zitat von FransvW Beitrag anzeigen
                  gelukt?
                  Nee.
                  We keep it English or Dutch...
                  Not yet.
                    I can program this whit the option (by bus). The first program for this product, I use the 057500.
                    What are changes of the programming?
                      Ok, So you program the IP Router via another device ?
                      Can you also program the IP Router by itself ? Without the 057500 ?
