hello
I have a ladder on one side where I have a button and the other got a motion sensor on the light when the button would then use the timing of the motion sensor to delete someone can help me as I do??
The motion sensor has an object called "external trigger" or alike. if you connect the manual switch with this object, a push on the switch will simulate movement and the motion sensor will then activate the light and deactivate it after timeout.
best regards, Swen
ps: it might be required to program the manual switch to always send "1"s when pushed. Depending on the motion sensor it might ignore "0"s on the external trigger.
2 Objekte, 6 Linien + KNX/IP-Bereich, HS 3 SW 2.8, Visu mit 2x 15"-Touch, Softwaregateway KNX/IP für 2x Novelan Wärmepumpe, viele Ideen und wenig Zeit
best regards, Swen
with this auxiliary input connected will continue will continue to do their normal functions detect movements and turn on the light
