HS "Listen-Ausgang dynamisch"
    Hello,
    I'm trying to fetch a line from the login list, without going via the web analyse.
    I see the function "Listen-Ausgang dynamisch", would that do the trick ?
    The help says:
    "Mit diesem Baustein besteht die Möglichkeit, sich an eine beliebige Stelle der Liste – auch an das Ende der Liste - zu setzen. Es werden dann der aktuelle und die 4 nachfolgenden Einträge ausgegeben. Soll nur ein Listeneintrag dargestellt werden, reicht es aus, Ausgang 1 zu belegen."
    How can I setup this function to get the last line of the list, if I don't know in advance how many lines are in the list.
    A practical example would help a lot
    Thanks
    Raymond
    Sorry if it is a dumb question, but I don't understand the explanation of the help
    This logic module is used in (selfbuilt-)playlists, you cannot get login data without webanalysis.
      Hi Matthias,
      Thank you for the super fast reply.
      My problem: I don't know in advance what to search for in the webanalysis. It is the time stamp, so it is variable.
      So far, I've put the time stamp in a variable with exactly the same format as in the login list, but if I can't search the login list with the content of a variable, I'm toast
      Any hint ?
      Thank you
      Raymond
