update fehlgeschlagen?
Dieses Thema ist geschlossen.
    [wiregate] update fehlgeschlagen?
    Hallo, ich hab grad gesehen das manche updates nicht vollständig geladen werden... kann mal einer drüber schauen.. DANKE
    Reading package lists... Building dependency tree... Reading state information... 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 6 not fully installed or removed. After this operation, 0B of additional disk space will be used. Setting up cometvisu-backend (0.4) ... Available modules: auth cgi-cometvisu-backend cgi fastcgi proxy rrdtool simple-vhost ssi ssl status userdir Already enabled modules: cgi-cometvisu-backend cgi Enabling cgi-cometvisu-backend: already enabled Run /etc/init.d/lighttpd force-reload to enable changes Stopping web server: lighttpd. Starting web server: lighttpd2015-06-11 00:09:37: (network.c.300) can't bind to port: 80 Address a lready in use failed! dpkg: error processing cometvisu-backend (--configure): subprocess post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of cometvisu-0.8: cometvisu-0.8 depends on cometvisu-backend; however: Package cometvisu-backend is not configured yet. dpkg: error processing cometvisu-0.8 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of webmin-wiregate: webmin-wiregate depends on cometvisu-0.8; however: Package cometvisu-0.8 is not configured yet. dpkg: error processing webmin-wiregate (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of wg-patch: wg-patch depends on webmin-wiregate (>= 0.3-72); however: Package webmin-wiregate is not configured yet. dpkg: error processing wg-patch (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of wiregated: wiregated depends on wg-patch; however: Package wg-patch is not configured yet. dpkg: error processing wiregated (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of cometvisu: cometvisu depends on cometvisu-backend; however: Package cometvisu-backend is not configured yet. dpkg: error processing cometvisu (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: cometvisu-backend cometvisu-0.8 webmin-wiregate wg-patch wiregated cometvisu E: Sub-process /usr/bin/dpkg returned an error code (1)
    Wir sehen uns das gerne an und beheben es auch, aber nicht hier sondern.
    0. Bitte nichts selbst probieren
    1. WireGate Wartungs VPN anstellen
    2. Ticket mit genauer Beschreibung der Sachlage und WG-Nummer unter support at wiregate dot de eröffnen
    3. Warten bis wir das behoben haben
    4. Updates einspielen
    Fertig
