Issue ETS5 Bus monitor (argument out of range)
    KNX/EIB Issue ETS5 Bus monitor (argument out of range)
    Dear,
    ETS 5.0.0.4 ;
    While the group address monitor is working fine, I get this using the bus monitor :
    2015-08-03 09:34:53,626 [1] INFO Falcon.TunnelingBusConnector - Connect tunneling bus connector to Tunneling, IPAddress=10.0.0.252, IPPort=3671, UseNat=False, type Tunneling, useNat False, mode Busmonitor
    2015-08-03 09:34:53,725 [1] INFO Falcon.TunnelingBusConnector - Disconnect tunneling bus connector from Tunneling, IPAddress=10.0.0.252, IPPort=3671, UseNat=False
    2015-08-03 09:34:53,725 [1] INFO Falcon.ConnectionManager - Release connector 'Tunneling, IPAddress=10.0.0.252, IPPort=3671, UseNat=False'.
    2015-08-03 09:34:53,726 [1] INFO Falcon.ConnectionManager - ...Finally released connector 'Tunneling, IPAddress=10.0.0.252, IPPort=3671, UseNat=False'.
    2015-08-03 09:34:53,726 [1] ERROR Falcon.Bus - System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
    Parameter name: statusCode
    at aan.f(afm A_0, Action`1 A_1, Action`1 A_2)
    at ab0.cl(ConnectionTypes A_0, ConnectorMode A_1, Action A_2, Action`1 A_3)
    at ab0.ez(ConnectorMode A_0)
    at Knx.Falcon.Bus.n(ConnectorMode A_0, Boolean& A_1)
    Anybody an idea please?
    Thanks,
    Tim
    Hello Tim,
    the current ETS5 Version is 5.0.6. Maybe updating solves your Problem.
    Otherwise, it is best to open a ticket at KNX Support. Be sure to include the exact identification (manufacturer, order number) of the KNX IP Interface.
    Klaus
      Hi Klaus,
      Thanks, even with 5.0.6 ; same story. It's a GIRA IP interface. Maybe I'll reset it and see what happens. However with EIB 3.x it works fine.
