Website auslesen, Problem mit Datenblöcken
    HS/FS Website auslesen, Problem mit Datenblöcken
    Hallo Leute,
    ich möchte eine eigentlich einfach gestrickte Website auslesen um an die Werte zu kommen:
    HTML-Code:
      <HTML> <head><meta http-equiv="refresh" content="5"><META Http-equiv="Content-Type" Content="text/html; charset=windows-1252"> <style type="text/css">body { font-family: Arial,Helvetica,"Trebuchet MS",   sans-serif; }h2{font-size: 18px;margin: 0px 0 0px 0px; color:#FFF;}</style> </head> <body bgcolor=#D6EBFF> <br> <center>[ <a href="/monitor.htm" ><span>monitoring</span></a> ] [  <a href="/setupn.htm" ><span>network setup</span></a> ] [  <a href="/setups.htm" ><span>snmp setup</span></a> ] [  <a href="/setupio.htm" ><span>I/O setup</span></a> ] [  <a href="/update.htm" ><span>update</span></a> ] [ <a href="/logout.htm" ><span>logout</span></a> ]</center> <br> <br>  <center> <center> <br> <br> </center> <table bgcolor="#6386BD" border=1 cellpadding=5 width=600> <tr height=60> <td width=150>Digital input 1<td width=150 bgcolor="#00FF00" align=center> <b>OPEN</b> <td width=150>Digital input 2<td width=150 bgcolor="#00FF00" align=center> <b>OPEN</b> <tr height=50> <td>Analog input 1<td> <h2>0.0V</h2> <td>Analog input 2<td> <h2>0.0V</h2> <tr height=50> <td>Temperature 1<td> <h2>10.0&#176;C</h2> <td>Temperature 2<td> <h2>7.8&#176;C</h2> <tr height=50> <td>Humidity 1<td> <h2>---%RH</h2> <td>Humidity 2<td> <h2>---%RH</h2> <tr height=60> <td>Relay output 1<td bgcolor="#FF0000" align=center> <b>OFF</b> <th colspan="2"><table> <tr> <td align=center> <form name=t1 method=POST> <INPUT TYPE=hidden name=tg1 value=1> <INPUT TYPE=submit  value=ON/OFF class=button> </form> <td align=center> <form name=p1 method=POST> <INPUT TYPE=hidden name=pl1 value=1> <INPUT TYPE=submit value=&nbsp;&nbsp;Pulse&nbsp;&nbsp; class=button> </form> </table><tr height=60> <td>Relay output 2<td  bgcolor="#FF0000" align=center> <b>OFF</b> <th colspan="2"><table> <tr><td align=center> <form name=t1 method=POST> <INPUT TYPE=hidden name=tg2 value=1> <INPUT TYPE=submit  value=ON/OFF class=button> </form> <td align=center> <form name=p1 method=POST> <INPUT TYPE=hidden name=pl2 value=1> <INPUT TYPE=submit value=&nbsp;&nbsp;Pulse&nbsp;&nbsp; class=button> </form> </table></table> </table> </center> </BODY> </HTML>
    Mich interessiert im ersten Step nur
    <td>Temperature 1<td> <h2>10.0&#176;C</h2> Also habe ich den HS wie in den Bildern konfiguriert, aber die Abfrage läuft nicht durch, warschienlich nur die ersten 3 Blöcke.
    29.09.2015 07:59:59 (IP: 10.110.195.100) (Port: 80) [B](Send: 70) 0x47 0x45 0x54 0x20 0x2f 0x6d 0x6f 0x6e 0x69 0x74 0x6f 0x72 0x2e 0x68 0x74 0x6d 0x20 0x48 0x54 0x54 0x50 0x2f 0x31 0x2e 0x30 0xd 0xa 0x48 0x6f 0x73 0x74 0x3a 0x20 0x31 0x30 0x2e 0x31 0x31 0x30 0x2e 0x31 0x39 0x35 0x2e 0x31 0x30 0x30 0xd 0xa 0x43 0x6f 0x6e 0x6e 0x65 0x63 0x74 0x69 0x6f 0x6e 0x3a 0x20 0x43 0x6c 0x6f 0x73 0x65 0xd 0xa 0xd 0xa[/B] GET /monitor.htm HTTP/1.0 Host: 10.110.195.100 Connection: Close [B](Recv: 2311) 0x48 0x54 0x54 0x50 0x2f 0x31 0x2e 0x31 0x20 0x32 0x30 0x30 0x20 0x4f 0x4b 0xd 0xa 0x43 0x6f 0x6e 0x6e 0x65 0x63 0x74 0x69 0x6f 0x6e 0x3a 0x20 0x63 0x6c 0x6f 0x73 0x65 0xd 0xa 0x43 0x6f 0x6e 0x74 0x65 0x6e 0x74 0x2d 0x54 0x79 0x70 0x65 0x3a 0x20 0x74 0x65 0x78 0x74 0x2f 0x68 0x74 0x6d 0x6c 0xd 0xa 0x43 0x61 0x63 0x68 0x65 0x2d 0x43 0x6f 0x6e 0x74 0x72 0x6f 0x6c 0x3a 0x20 0x6e 0x6f 0x2d 0x63 0x61 0x63 0x68 0x65 0xd 0xa 0xd 0xa 0x3c 0x48 0x54 0x4d 0x4c 0x3e 0xd 0xa 0x3c 0x68 0x65 0x61 0x64 0x3e 0x3c 0x6d 0x65 0x74 0x61 0x20 0x68 0x74 0x74 0x70 0x2d 0x65 0x71 0x75 0x69 0x76 0x3d 0x22 0x72 0x65 0x66 0x72 0x65 0x73 0x68 0x22 0x20 0x63 0x6f 0x6e 0x74 0x65 0x6e 0x74 0x3d 0x22 0x35 0x22 0x3e 0x3c 0x4d 0x45 0x54 0x41 0x20 0x48 0x74 0x74 0x70 0x2d 0x65 0x71 0x75 0x69 0x76 0x3d 0x22 0x43 0x6f 0x6e 0x74 0x65 0x6e 0x74 0x2d 0x54 0x79 0x70 0x65 0x22 0x20 0x43 0x6f 0x6e 0x74 0x65 0x6e 0x74 0x3d 0x22 0x74 0x65 0x78 0x74 0x2f 0x68 0x74 0x6d 0x6c 0x3b 0x20 0x63 0x68 0x61 0x72 0x73 0x65 0x74[/B] HTTP/1.1 200 OK Connection: close Content-Type: text/html Cache-Control: no-cache [HTML] [head][meta http-equiv="refresh" content="5"][META Http-equiv="Content-Type" Content="text/html; charset [B](Gesamt: 5) (Work: 3) (Typ: Liste) (OK: 0)[/B]
    Die Frage ist nun wie muss der Datenblock aussehen damit ich den Wert in eine Variable bekomme? Warscheinlich regt er sich wegen dem Steuerzeichen direkt hinter dem Wert auf... Kann da jemand helfen? datenblock1.png
    Ein Update:
    Es funktioniert mit einem Umweg:
    Er erkennt irgendwie den Block
    <td>Temperature 1<td> nicht und bricht dort immer ab.
    Mit dem Durchhangeln über die H2 Tags geht es aber.
    Das ist aber extrem unschön wenn da noch mehr Werte kommen - ein haufen Tiparbeit.
    Weis jemand warum der Block nicht richtig erkannt wird und dann alles abgebrochen?
      Hi.
      Leider habe ich kein HS und kann dir nicht wirklich weiterhelfen, aber kann trotzdem ein bisschen Senf geben - v.a. weil niemand darauf geantwortet hat.
      Sehr wahrscheinlich liegt das Problem an falscher HTML Aufbau. Du hast leider massiv viele Fehler im HTML. Probier doch mal mit https://validator.w3.org
      1. Tab "Validate by Direct Input" klicken
      2. HTML Source Code einfügen
      3. Check
      4. Kritische Fehler beheben.
      Zurück zu deinem Problem:
      HTML-Code:
      ist nicht zulässig - müsste mit </td> abgeschlossen werden. Vielleicht bricht es deshalb dort ab? Beispiel wie eine Zelle aufgebaut ist: https://www.w3.org/wiki/HTML/Elements/td
      Generell: Werte aus einer HTML Seite herauszulesen ist nie eine gute Idee - besser wäre direktere Abfragen per JSON, XML, CSV/TSV oder notfalls Plain-Text. Falls du einer Skriptsprache mächtig bist, dann kannst du auch sogar die Tabelle laufend aktualisieren ohne, dass die Seite komplett neu geladen werden muss.
      LG, Christoph
        Hallo Christoph,
        danke für deine Antwort.
        das mit den falschen Tags habe ich schon gesehen aber es ist eine Website von einem fertigen Gerät und die kann ich nicht ändern. Man kommt nur noch per snmp an die Werte dran. Das kann der HS aber nicht und deswegen bleibt mir nur die Variante.
        Naja es funktioniert ja erstmal.
        falls noch jemand mit liest, kann ich denn auch per Senden Befehl "Buttons drücken" ?
