English Speaking - Connecting to KNX Bus Line Externally IP
    hi
    i am working on a KNX installation in a school and I have installed a Gira 216700 IP router on the KNX line. I have it connected to the network through a Network Switch .. i want to be able to connect to the KNX line externally from my office. i am just wondering how i can do this?
    thanks paul
    VPN is the solution!
      Or hardware with software in a box: http://www.voltus.de/hausautomation/...mnetzwerk.html
      Danke und LG, Dariusz
        I use port forwarding in my FritzBox modem.
        All UDP port 3671 traffic is forwarded to port 3671 of my IP/KNX interface (a Siemens N148/21).
          activate your port forwarding = drill a whole in your fire-wall … to avoid it means to use VPN
