If I modify the numbers of devices in a GA at the ETS level (i.e. the Status GA, 0/0/102 in this case), do I need to re-import this GA in the HomeServer ?
Also, what is the relationship between the ETS flags and the HS flags ?
Are they the same after in import or are they totally different. I think this topic has already been discussed but can't find it back.
How can I issue a "Read" with ETS ? (not with the Group Monitor, of course).
I'm still busy with my actuator which has no feedback status.
The Visu and the PB LEDs are connected in the same GA as the actuator switch channel. That works fine.
When I issue an "all off" command ( i.e. sending a 0 to GA containing all lights actuator) Tha actuator goes indeed Off, but the status is not updated.
When I issue an explicit Read with ETS on that actuator channel, the status is updated.
Hence the question, how can I do it with ETS and GA ?
Putting a second GA behind the switching GA (hearing address) doesn't help. That second GA doesn't change state when the actuator changes state.
Any idea or simple work around ? (I don't want to use the HS and a Baustein to do that, seems like an overkill)
Then the status should be up-to-date if you press all-off.
The status is up-to-date on all GA, except the 4 mentionned above.
For those 4, the status is up-to-date when I hit a PushButton or click in the Visu.
It is NOT up-to-date via the "all-off"
Could it be a Flag problem ? I've already messed around , AFAIK the "update" flag, should do the trick, that is, it updates partners when the status is changed from an external source ?
I've attached a picture. 0/0/101,103,105,107 are the GA switch actuators.
0/7/6 is the "all off" GA
I've had no other solution than to write a function with the GLE to force a re-read of the actuator channel, whenever an "All-off" is triggered.
Now the status is updated correctly .
