Gira Logic module - 2070 00
    Hello,
    I have started pre-programming a project that will use the Gira 2070 00 logic module and have never worked with it before so I have some question about it and hopefully some of you have already worked a bit with it and maybe could answer my questions!
    1. I will have the Gira LM on the main line and I will have 4 line couplers. The parameter and comissioning is through Project assistant and no objects will show in ETS.
    How will the used group adresses be put inside the filter table of the line couplers? Do I manually have to put them in, or do I make some sort of download of the application through ETS after comissioning and then do a partitial programming of the line couplers?
    2. Is comissioning only availble through IP-interface, or can I use the TP/BUS cable through either a IP-router or USB interface to do the comissioning aswell?
    3. I have built a logic that will trigger 6 scenes on same group adress at once. I put 6 independent output and connecter same GA to all of them but sending different Value through Value generator to them. Will this work in real life, that it will send 6 telegrams on same GA with different values triggering different scenes? The scenes are in different rooms, so they wouldn't "collide" with eachother.
    Thanks in advance
    I have read the manual and acoording to it, I should be able to perform comissioning through the KNX TP aswell.
    One thing the manual doesn't mention is how line couplers will be affected since no programming is done through ETS.
