Hello, I am new to KNX and i have done alot of research on a the internet about KNX but i will like to know which of the KNX manufacture is very reliable and does not cost much .I want to install a system Which can control lighting , music with radio tuner for each room and CCTV, and alarm with for door and windows contro sensor .i have come across trivum, gira, divus and dont know which one to chose
but Gira is more expensive. when i check the price on the internet. what i want is fairly price controller which an app and to intergrate alot of diffrent manufacture
can i use different product from different manufactures together and use a single app or controller to control them because i like the gira door station which support pip and also like trivuim audio and also like the ABB alarm panel ..some controller are cheap then others
