Packet sender
    HS/FS Packet sender
    Hello,
    Is there a simple packet sender for Homeserver? The inbuilt one works but adds a ~10sec delay for some reason. Or is there a way to remove the delay?
    For refference: Sending a simple packet to a Crosspoint Audio switch
    With the program packet sender i just send a simple command to port 23, for example "1*1!" which ties input 1 to output 1.
    Using the program i can send commands without a delay so its not in the switch, using wireshark shows that its the homeserver that has the delay.
    Thnks
    What type of HS?
      Homeserver 4. 4.2
        It seems to be a "normal problem" in the HS-firmware.
        Here is a thread with similar problems:
        https://knx-user-forum.de/forum/%C3%...r-tcp-abfragen
        What kind of packets you will send? UDP/TCP?
        In my opinion you have to close the connection (if TCP) on server-side. Otherwise the HS will wait 10 seconds for an internal timeout.
        Baustelle 2.0 !
          Thank you, that other thread pointed me to the solution to my problem.
          In the Web Pages/IP Devices there is a checkbox End connection after certain number of data
          I checked that and set the lenght to 10 (the switch always replies back with its own id which is 10+ chars)
          And now the 10 second delay is gone.
          So for me at least that fixes my issue and i can spam commands to the switch and it will react each time.
            Nice hint!
            I will try to remember this for not running in same error in future.
            Baustelle 2.0 !
