Gira Türkommunikation with QC
    HS/FS Gira Türkommunikation with QC
    I'm trying to set up my Gira Türkommunikation system. The devices I have are an stainless steel doorstation with video, the video terminal, TKS-IP unit and a gira HS with a touchscreen.
    I can get the doorstation connected to the videoterminal but I fail to get the indoor station, which in my case is the HS with touchscreen, to connect. The HS seems to find the TKS-IP but the indoor station is not programmed. Normally this should be done by holding the light button for 3s.
    So I'm thinking that I need an indoor station to get this working or is there another way to get things working?
    I'm not in need of a indoor station since I want to use the touchscreen with the door communication system.
    I read through the manuals but can't find any info. So any advice is welcome.
    Did you configure the TKS-IP-Gateway through the Webinterface?
      I did configure the tks ip through the web interface.
      I have a suspicion that I need to do something to register the tks ip on the video terminal! But I can't find a way to do it.
      I see a button on the tks but it is not described in the manual. It looks like a programming button on a Knx device.
