Gira 2167 + 2070 ethernet connection
    Hello,
    I have both Gira 216700 router and 207000 Logikmodul.
    I have noticed that both devices have 2xRJ45 each.
    Is it possible that I connect both devices together with a patch Cable, and then only have 1 Ethernet Cable from the network switch?
    Or must I connect both devices individually to the network?
    I also have a Schneider/merten HomeLync (Logic controller) with only 1 RJ45, would this one also be possible to connect to the same Loop if using only 1 Ethernet Cable from Network.
    Thanks!
    You can connect them directly by each other using the 2xRJ45 (there is a 2-port ethernet switch inside the devices). You can connect the Schneider device to the same "loop".
      Thank you!
      That's actually a really great feature.
      Regards
      Mani
