Graph timeline wrong
    HS/FS Graph timeline wrong
    I noticed that the temperature archive does not produce a correct graph on the iPad for at least the Week view.
    To test this I made an archive that just takes the day of the week as Communication Object.
    Cycle is 10 minutes.
    Ring memory is 1008 (7*24*60/10=1008 minutes)
    When moving a finger on the graph you would expect the change to the next day to occur at midnight.
    Wrong...
    Last night increase of the day of the week shows around 20:20 (3 hours 40 minutes early)
    the days before: 17:10 14:05 11:00 08:00 04:55 01:55
    As you can see the timeline shifts about 3 hours and 5 minutes per day.
    The timeline on QuadClient shows correct.
    What you see is not necessarily wrong - it just is different from what you expect. Assuming you use the Visu, then the x-axis is dynamically scaled. The tick marks will show up with a spacing as you defined. The first tick mark is placed dynamically, where it is placed depends on your archive, your settings, and the current time.
    My guess is that if you define your axis settings right for your scale and graph size, the display will be acceptable.
    Bram
      Thanks Bram.
      I'm using the Gira app for iPad and iPhone.
      When you put your finger in the graph you get a vertical line starting at the X-axis up to the top of the graph.
      This is the result I get putting that vertical line as accurately as possible on the date tick on the X-axis:
      14-03 10:39
      13-03 07:38
      12-03 04:43
      11-03 01:31
      10-03 22:18
      09-03 18:18
      Last night increase of the day of the week now shows around 19:55 so that changes as well...
      In short, the timeline does not correspond with the Y-axis values nor with the time info when touching the graph.
