Even on the Light and Building 2016 Gira and ISE were very..very sceptic.. and didn't gave me an exact release date.
I could make up that: "Not before summer, but this year." A new App would come out.
There SHOULD also come out a new Experte and HS firmware because it should work with the new IP Router security (encrypted KNX telegrams in an IP header).
The firmware for the IP router is already available.. but it can't communicate securely with the HS.
All should come this year.. but when...?
BTW. About the Turrcommunication 106.. which was already marketed at L&B 2014. but still not comming (until NOVEMBER 2016!).. it was said that the whole unit was re-engineered because it was not good enough.. well, if you already know that it won't be before november2016,. I think they;re still working on it.
