Simple & cheap multi-room
    [OT] Simple & cheap multi-room
    Now that I've my MusicPal nicely integrated in the HS, I thought about putting one device in each room.
    But the power cable is an annoyance. AFAIK there is no PoE model for the MusicPal.
    So I'm looking for a simple & cheap solution, based on PoE (hence RJ45, no Wi-Fi), able to play music in each room.
    Any experience or tip is welcome.
    If you're happy with the Musicpal, maybe a POE-Splitter like TL-POE10R is an option to supply power to it from PoE-Switch or with injector on the other end. I'm happy with these, just check if 2A@5V is sufficient..
    Makki
    -> Bitte KEINE PNs!
