[HS+TKS IP GW] Klingel/Anrufzustand Beenden
    Hello, (sorry to make this thread in English in the first place)
    I have several Gira Türstations with Fingerprint, a TKS-IP Gateway and a HS.
    When a guest pushes the button, I made it to ring my phone and play a RINGGG sound on the Sonos, that all works well.
    Sometimes I want to open the door immediately instead of answering the phone first. So I want it to STOP ringing when I open the door.
    I use: "16951 - Anrufzustand TKS-Bus Teilnehmer beenden".
    (see the screenshot)
    - Send a 1 to the Trigger (input 1)
    - Static value of '3' on 'TKS-Bus Teilnehmer' (input 2).
    It does not work!
    I have connected the output to a debug_text_object, just to see if the baustein works. I see a hex/text string ouput so I assume it works.
    I also checked the HS Debug page: (http://192.168.1.1/hslist?lst=debug&...XXX#TK-GATEWAY )
    I see it increments the 'Anz. Send' and updates the 'Last Send'.
    I thought it may be a problem between communication between he HS and the TKS gateway, maybe authentication or network issues. So I tried another Send baustein: "16932 - Türöffner-Automatik TKS-Client abfragen/einstellen". When I send something, I see an incomming message using the "Türkommunikation / Anzeige-Basisparameter" baustein, so I assume that works.
    Can someone help me out here?
    This gallery has 1 photos.
    Zuletzt geändert von Roeller; 21.06.2016, 13:31.
    Does anyone have such a setup?
      Hi Roeller, i have exactly the same setup and it works. See my logic picture attached.
      Does your Trigger-Input works as expected?
      hth, mjoe
        Because of the fact that it is still not working, I'm re-checking everything, also my wiring. Can someone tell me if the wiring is OK? (Bus IN / Bus OUT) ?
        See picture attached.
          https://knx-user-forum.de/forum/öffe...998#post911998
            Hi Roeller
            Here's my Logik.
            NB: 100/0/50 sends an 8-Bit Datatype (-128...127)
            100/0/49 is a 1 Bit
            100/0/48 14-Byte Text
            Maybe this helps.
            Since I'm not an electrician, I can't say anything about your wiring. If your Setup works (expect the Phone-Thing) I guess the wiring is OK.
            For me, Gira TKS should urgently get an update anyway... there are so many possibilities but so much hassle...
            Bye
            Chris
            HS4 - Trivum - Ekey net - ETS6 - HS-Experte 4.13 - PV-Anlage mit Fronius Symo Gen24 und Symo 10.0-3-M
