knxd Startoptionen bzgl. Logging
    ich starte den KNXD mit diesem Kommando:
    command: knxd --error=0  -t 65535 -D -T -R -S -i --GroupCache --no-tunnel-client-queuing -b ipt:192.168.177.24
    Das wiederum führt zu sehr viel Log-Output:
    Layer 1(013B2510,5793E5FA) Recv L_Data low from 1.0.15 to 5/2/13 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 3(01370120,5793E5FA) Enqueue L_Data low from 1.0.15 to 5/2/13 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 3(01370120,5793E5FA) RecvData L_Data low from 1.0.15 to 5/2/13 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 8(013808B0,5793E5FA) Send_Route L_Data low from 1.0.15 to 5/2/13 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 1(01380DF0,5793E5FA) Send(013): 29 00 BC D0 10 0F 2A 0D 03 00 80 00 00
    Layer 0(01380DF0,5793E5FA) Send(019): 06 10 05 30 00 13 29 00 BC D0 10 0F 2A 0D 03 00 80 00 00
    Layer 0(013B2650,5793E5FB) Recv(023): 06 10 04 20 00 17 04 6D 78 00 29 00 BC E0 10 0F 2A 0D 03 00 80 00 00
    Layer 1(013B2650,5793E5FB) Recv(017): 04 6D 78 00 29 00 BC E0 10 0F 2A 0D 03 00 80 00 00
    Layer 1(013B2650,5793E5FB) Send(004): 04 6D 78 00
    Layer 0(013B2650,5793E5FB) Send(010): 06 10 04 21 00 0A 04 6D 78 00
    Layer 1(013B2510,5793E5FB) Recv L_Data low from 1.0.15 to 5/2/13 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 3(01370120,5793E5FB) Enqueue L_Data low from 1.0.15 to 5/2/13 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 3(01370120,5793E5FB) RecvData L_Data low from 1.0.15 to 5/2/13 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 8(013808B0,5793E5FB) Send_Route L_Data low from 1.0.15 to 5/2/13 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 00 00
    Layer 1(01380DF0,5793E5FB) Send(013): 29 00 BC D0 10 0F 2A 0D 03 00 80 00 00
    Layer 0(01380DF0,5793E5FB) Send(019): 06 10 05 30 00 13 29 00 BC D0 10 0F 2A 0D 03 00 80 00 00
    Layer 0(013B2650,5793E5FC) Recv(023): 06 10 04 20 00 17 04 6D 79 00 29 00 BC E0 10 10 35 65 03 00 80 00 3E
    Layer 1(013B2650,5793E5FC) Recv(017): 04 6D 79 00 29 00 BC E0 10 10 35 65 03 00 80 00 3E
    Layer 1(013B2650,5793E5FC) Send(004): 04 6D 79 00
    Layer 0(013B2650,5793E5FC) Send(010): 06 10 04 21 00 0A 04 6D 79 00
    Layer 1(013B2510,5793E5FC) Recv L_Data low from 1.0.16 to 6/5/101 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 00 3E
    Layer 3(01370120,5793E5FC) Enqueue L_Data low from 1.0.16 to 6/5/101 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 00 3E
    Was verstehe ich hier falsch? Wie bekomme ich den knxd soweit zum schweigen, dass er nur noch Warnungen und Fehler ausgibt?
    Hendrik
    Der Wert hinter dem Parameter "-t" gibt an, wieviel geloggt werden soll. 65535 ist Maximum (alle 16 Bit gesetzt).
    Gib mal "knxd --help ein" ...
    Greetinx,
    Udo
    Zuletzt geändert von umatz; 07.08.2016, 16:29.
