A "real" KNX power supply has a specific characteristic on power down. KNX nodes detects a power failure by measuring the voltage. If the voltage drops below a specific value, the KNX node assumes that the power goes down. The node can then save some values into persistent memory. For that it needs power. Therefore the knx power supply has to keep the voltage stable at this low value for a specific amount of time.
A normal power supply doesn't has this characteristic. If the node begins to write into persistent memory the power gets lost and the node may have written only partial configuration which may lead to problems on power up.
Now it depends on how many nodes you have which really wants to store values into persistent memory. I think in my installation I have no such device.
I've only opened some older power supplies and there I could see that they follow this characteristic (by the capacitors and the transformer had an extra output and the like).
