Siri API for the Gira HomeServer app
    I figured out what was wrong: ;-)
    The TUL must be programmed to work as a TPUART device (it does not work like a USB device as is the case of the GIRA KNX-UBS interface):
    Here's the procedure I used to get it working as a tpuart device (might be useful for somebody)
    Programming TUL (TP-UART USB Light) adapter
    1) Install the TUL programming software (dfu-programmer)
    sudo apt-get install dfu-programmer
    2) Fetch the Firmware
    sudo wget -O TPUARTtransparent.hex http://busware.de/tiki-download_file.php?fileId=54
    3) Flash the TUL:
    #Note: I found that it was not necessary to press the program button on the bottom of the TUL
    Run:
    sudo dfu-programmer atmega32u4 erase --force
    sudo dfu-programmer atmega32u4 flash TPUARTtransparent.hex
    sudo dfu-programmer atmega32u4 reset
    sudo reboot
    The TUL will now show up as: /dev/ttyACM0 which is owned by root
    4) Change device ownership
    Run:
    udevadm info --attribute-walk /sys/bus/usb/drivers/cdc_acm/*/tty/ttyACM0 | grep KERNELS | head -3 | tail -1
    < will return KERNELS==“something”>
    Add the following line to:
    sudo vi /etc/udev/rules.d/90-knxusb-devices.rules
    # busware.de TUL (TP-UART USB Light) adapter
    SUBSYSTEM=="tty", ATTRS{idVendor}=="03eb", ATTRS{idProduct}=="204b", ACTION=="add", KERNELS=="something", SYMLINK+="ttyKNX1", OWNER="knxd"
    Note: you need to replace the something with whatever udevadm displayed above
    Force new settings:
    sudo udevadm test /sys/bus/usb/drivers/cdc_acm/*/tty/ttyACM0
    Verify that /dev/ttyKNX1 exists and belongs to "knxd":
    ls -lL /dev/ttyKNX1
    The TUL will now work as a TPUART device:
    5) Add -b tpuarts:/dev/ttyKNX1 to the options in /etc/knxd.conf.
    sudo vi /etc/knxd.conf
    cat /etc/knxd.conf | grep ^KNXD_OPTS
    KNXD_OPTS="-e 0.0.100 -E 0.0.101:7 -D -T -R -S -i 6720 -b tpuarts:/dev/ttyKNX1"
    6) Restart the knxd
    sudo systemctl restart knxd
    Check /var/log/syslog for errors:
    tail -f /var/log/syslog
    Check that is it listening on port 6720:
    netstat -na | grep 6720
    7) Test your KNX address groups (example address group 0/0/3)
    Turn ON light:
    knxtool groupswrite ip:localhost 0/0/3 1
    Turn Off Light:
    knxtool groupswrite ip:localhost 0/0/3 0
