Danke dir, nutzt du zusätzlich auch den Bewässerungs Baustein?
Gira HS Gartenbewässerung
@Axel,
i'm also using your logic and it's working ok except for the manual function. I use a main valve and 7 zone valves. When I try to activate one of the zones the main valve doesn't open.
I've all inputs and outputs with the same zone GA except for the Start/Stop/Kaskade where I use an iKO. Output "Lauft/Ende" is connected to the main valve GA.
My thought was that when selecting a zone manually "A1" would be active as well. The zone valve opens but the main valve stays closed.
Any idea's?
