Changing "Homeserver" scenes without graphical interface?
    Hi.
    I have not yet bought the Gira Homeserver (expensive), and have some questions before doing so...
    Is it possible to changes "internal" homeserver scenes without the graphical interface?
    Say I have 40 different scenes configured in the Homerserver for the whole house and 5 of these are for the kitchen. Is it possible to cycle through the 5 different scenes from a physical KNX "button" for the kitchen, or do I have to go into the graphical interface to do this?
    Is there no way of starting scenes/sequences/.... from the KNX bus directly, or do you have to go through the graphical interface to activate any "Homserver functions"?
    Regards.
    Kaj
    A scene defined in the HS is not much different from a scene defined in another KNX device. You can call it by sending a value on the bus for the GA associated with that scene. Same for triggering a sequence. The logic in the HS listens for a particular GA status and triggers whatever is defined in your logic. The HS does not care if the action is triggered by pushing a button on a KNX device or touching something on a graphical interface - which is really just another KNX-device.
    Bram
