1 bit dimmer (fade in/fade out) for LEDs
    [HS-Logik] 1 bit dimmer (fade in/fade out) for LEDs
    I am looking for a HS logic module to allow soft LED lighting. I was thinking of a module with 3 inputs: 8 bit (0-255) max brightness, 1 bit on/of, 8 bit (0-255) speed and one output 8 bit (0-255). Nice to have: linear/log mode, fix time/fix speed. RGB version more than welcome! Thanx in advance for any references.
    I expect this can be solved with the application of the dimmer itselve without using the HS. Which dimmer do you use?
    Zapft ihr Narren der König hat Durst
      I use DMX led drivers connected to Artnet Node. Connection between KNX and ArtNet environment is done by HS. With HS logic modules I do translation of KNX telegrams into DMX channel values and triger sending Artnet sequences via TCP/IP. The role of Logic module I am looking for is to add smooth transitions between on/off.
