Home Assistant - Heizung Fehlerneldung
    Hi Leute,
    ich nutze als Visu Homeassistant. Alles, inkl. KNX, noch relativ neu für mich.
    Da im HomeAssistant Forum KNX noch eine eher zweitrangige Stellung hat, hoffe ich, dass mir hier jemand weiterhelfen kann. Ich bekomme folgende Fehlermeldung ausgespuckt:
    PHP-Code:
    > 2019-03-10 15:04:15 WARNING (MainThread) [xknx.log] Could not read value of <ClimateMode name="Bad OG Mode" group_address_operation_mode="GroupAddress("3/3/9")" group_address_operation_mode_state="None" group_address_controller_status="None" group_address_controller_status_state="None" group_address_controller_mode="None" group_address_controller_mode_state="None" /> 3/3/9 > 2019-03-10 15:04:16 WARNING (MainThread) [xknx.log] Could not read value of <Climate name="Bad OG" temperature="None/GroupAddress("3/0/9")/<DPTArray value="[0xc,0x15]" />/20.9" target_temperature="GroupAddress("3/2/9")/None/None/None" setpoint_shift="None/None/None/None" setpoint_shift_step="0.5" setpoint_shift_max="6" setpoint_shift_min="-6" group_address_on_off="None/None/None/None" /> 3/3/9 > 2019-03-10 15:04:17 WARNING (MainThread) [xknx.log] Could not read value of <ClimateMode name="Schlafzimmer Mode" group_address_operation_mode="GroupAddress("3/3/8")" group_address_operation_mode_state="None" group_address_controller_status="None" group_address_controller_status_state="None" group_address_controller_mode="None" group_address_controller_mode_state="None" /> 3/3/8 > 2019-03-10 15:04:18 WARNING (MainThread) [xknx.log] Could not read value of <Climate name="Schlafzimmer" temperature="None/GroupAddress("3/0/8")/<DPTArray value="[0xc,0x24]" />/21.2" target_temperature="GroupAddress("3/2/8")/None/None/None" setpoint_shift="None/None/None/None" setpoint_shift_step="0.5" setpoint_shift_max="6" setpoint_shift_min="-6" group_address_on_off="None/None/None/None" /> 3/3/8 > 2019-03-10 15:04:19 WARNING (MainThread) [xknx.log] Could not read value of <ClimateMode name="Wohnbereich Mode" group_address_operation_mode="GroupAddress("3/3/2")" group_address_operation_mode_state="None" group_address_controller_status="None" group_address_controller_status_state="None" group_address_controller_mode="None" group_address_controller_mode_state="None" /> 3/3/2 > 2019-03-10 15:04:20 WARNING (MainThread) [xknx.log] Could not read value of <Climate name="Wohnbereich" temperature="None/GroupAddress("3/0/2")/<DPTArray value="[0xc,0x65]" />/22.5" target_temperature="GroupAddress("3/2/2")/None/<DPTArray value="[0xc,0x1a]" />/21.0" setpoint_shift="None/None/None/None" setpoint_shift_step="0.5" setpoint_shift_max="6" setpoint_shift_min="-6" group_address_on_off="None/None/None/None" /> 3/3/2 > 2019-03-10 15:04:21 WARNING (MainThread) [xknx.log] Could not read value of <ClimateMode name="Kinderzimmer Mode" group_address_operation_mode="GroupAddress("3/3/6")" group_address_operation_mode_state="None" group_address_controller_status="None" group_address_controller_status_state="None" group_address_controller_mode="None" group_address_controller_mode_state="None" /> 3/3/6 > 2019-03-10 15:04:22 WARNING (MainThread) [xknx.log] Could not read value of <Climate name="Kinderzimmer" temperature="None/GroupAddress("3/0/6")/<DPTArray value="[0xc,0x10]" />/20.8" target_temperature="GroupAddress("3/2/6")/None/None/None" setpoint_shift="None/None/None/None" setpoint_shift_step="0.5" setpoint_shift_max="6" setpoint_shift_min="-6" group_address_on_off="None/None/None/None" /> 3/3/6 > 2019-03-10 15:04:23 WARNING (MainThread) [xknx.log] Could not read value of <ClimateMode name="Büro Mode" group_address_operation_mode="GroupAddress("3/3/10")" group_address_operation_mode_state="None" group_address_controller_status="None" group_address_controller_status_state="None" group_address_controller_mode="None" group_address_controller_mode_state="None" /> 3/3/10 > 2019-03-10 15:04:25 WARNING (MainThread) [xknx.log] Could not read value of <Climate name="Büro" temperature="None/GroupAddress("3/0/10")/<DPTArray value="[0xc,0x24]" />/21.2" target_temperature="GroupAddress("3/2/10")/None/None/None" setpoint_shift="None/None/None/None" setpoint_shift_step="0.5" setpoint_shift_max="6" setpoint_shift_min="-6" group_address_on_off="None/None/None/None" /> 3/3/10
    offensichtlich hat es mit der Heizung zu tun. Leider kann ich mit den ganzen geforderten GA's nix anfangen. Mein Integrator hätte alles korrekt konfiguriert laut seiner Aussage.
    Jemand eine Idee? Wenn noch was benötigt wird, poste ich es gerne.
    Danke für euren Support!
    Magst einmal die dazugehörige Config posten?
      Gerne
      PHP-Code:
      climate:
      - platform: knx
           temperature_address: '3/0/2'
           target_temperature_address: '3/2/2'
           operation_mode_address: '3/3/2'
         - platform: knx
           temperature_address: '3/0/6'
           target_temperature_address: '3/2/6'
           operation_mode_address: '3/3/6'
         - platform: knx
           temperature_address: '3/0/10'
           target_temperature_address: '3/2/10'
           operation_mode_address: '3/3/10'
           operation_mode_state_address: '3/4/10'
           controller_status_state_address: '3/1/10'
           min_temp: 19
           max_temp: 21
         - platform: knx
           temperature_address: '3/0/9'
           target_temperature_address: '3/2/9'
           operation_mode_address: '3/3/9'
         - platform: knx
           temperature_address: '3/0/8'
           target_temperature_address: '3/2/8'
           operation_mode_address: '3/3/8'
      Beim Büro habe ich noch ein wenig mit den GA´s rum experimentiert bis ich erfahren habe, dass es gar nicht wirklich palettisiert ist, da der Autor voll ist
        ich nehm jetzt mal an dass die fehlende einrückung von "-platform: knx" im Wohnbereich nur ein copy&paste fehler ist?
        wenn es die adressen nicht gibt, klingt die fehlermeldung logisch. aber bei den anderen räumen sind die addressen korrekt konfiguriert?
        Meine Config:
        PHP-Code:
        climate:
           - platform: knx
             temperature_address: '4/0/0'           # Ist Wert
             setpoint_shift_address: '4/2/0'        #  Sollwertverschiebung
             target_temperature_address: '4/1/0'    # Soll Wert
             operation_mode_address: '4/3/0'        # Betriebsmodus
             operation_mode_state_address: '4/4/0'  # Betriebsmodus status
           - platform: knx
             temperature_address: '4/0/1'           # Ist Wert
             setpoint_shift_address: '4/2/1'        #  Sollwertverschiebung
             target_temperature_address: '4/1/1'    # Soll Wert
             operation_mode_address: '4/3/1'        # Betriebsmodus
             operation_mode_state_address: '4/4/1'  # Betriebsmodus status
        sonst schauts ja ok aus. auf welcher HomeAssistant Version bist du? 0.88 hat bei mir ganz komische probleme gemacht, ich hab jetzt 0.89.1 und eigentlich läuft alles wie es soll.
