send only off command to light
    I do not speak germany, so sorry I will write in english.
    It's possible in KNX to send only OFF command to light, for example switch off all room light. with out toggling ON then OFF.
    Regards,
    Omanix
    Hi Omanix,
    most switches can be configured to send fixed values also, i.e. only send OFF when pressed.
    Regards
    Volker
      Or change your switch to operation mode "blinds" and command "open". Now connect your groupadress with the "stop" Object.
