Try to import .hslz file, get fault message.
    HS/FS Try to import .hslz file, get fault message.
    Hello!
    I'm a new user of thise interesting forum.
    I have a Gira Homeserver 4 in my home, and have programmed knx in 3 years now.
    I have not so much practise with the HS.
    Today I tryed to download some of the logic-blocks in this forum. But I just get a fault message, can someone help?
    Screenshots;
    Thanks!
    This gallery has 2 photos.
    The LBS "Sperre" is a standard LBS, which exists in the Expert Software. You can not import this File.
      Thanks, I found it Lock Out...
