Jung 5094X TSM and scenes
    Hi!
    I´m tring to fix the following scenario:
    If I set up a a Jung 509x TSM push button with a Venetian blind function and choose toggle.
    Is it possible to turn on and off lights with a short press and recall a scene with a long press?
    I'd like to turn the spotlights on 100% but I want to be able to turn them on att maybe 30% if I get up at night.
    Or is there any easier way to cconfigure this?
    Kind regards
    Mikael
    Anyone?
      Hello Mikael,
      it is really possible.
      The Button switch must be : 2-Channel-Operation
      First Switch on and off toggle
      Second 1byte valuator for Scenenumber
      Jens
        Hello Jens!
        Where do I enter the scenenumber? And does it react to the long push?
        Kind regards
        Mikael
          You write with the ETS the Scenenumber in the application.
          its react to the long push. The time between short and long push you can change
