KNX Dali system and ballasts(dimmer)
    DALI KNX Dali system and ballasts(dimmer)
    Hello everyone!
    Probably this question is already somewhere is this forum, but since I have very hard to understand in german I would hope on some help in english.
    First of all I would like in integrate Dali system with KNX Getaway (I'm planning to buy ABB DG / S 1.64.1.1) for my home. I would like it to control LED strips, recessed sealing lights(GU10) and pendant lights(E27). All LED.
    So I understand that I need a 5 x 1,5 wire(2 of them for Dali) to each light unit I want to control separately.
    For LED strips I need transformator with dimmer that will convert 220V to 12V, right? Would something like this would do ? https://www.amazon.de/gp/product/B00...KR8XB7XF&psc=1
    As for recessed light I'm planning to install something like this https://www.amazon.de/SLV-115566-KAD...ds=slv+kadux+3 with https://www.amazon.de/Philips-GU10-L...10+led+dimmbar
    These are 240V lamps. So what is proper ballast(dimmer) for these types of lamps?
    And one more question. When I connect light to Dali ballast(dimmer) and that connect to main electricity line will the light will be off by default? Because there won't be any switch between them.(Control via KNX push button)
    I would really appreciate some help.
