Frage fur Topologie (IP Router 1.0.0, Homeserver 0.0.10)
    (sorry to continue in English)
    It is possible to have the following topology:
    0.0.10 Homeserver
    1.0.0 IP-ROUTER1
    1.1.x Room-A
    1.2.x Room-B
    1.3.x Room-C
    1.4.x Room-D
    2.0.0 IP-ROUTER2
    2.1.x Room-M
    2.2.x Room-N
    2.3.x Room-O
    3.0.0 IP-ROUTER3
    3.1.x Garten-1
    3.2.x Garten-2
    3.3.x Garten-3
    Lines 1.0.x - 1.4.x are just 1 line (all connected to each other)
    Lines 2.0.x - 2.3.x are also just 1 line (all connected to each other)
    Lines 3.0.x - 3.3.x are also just 1 line (all connected to each other)
    The homeserver is using 0.0.10
    This is al done just to have a better overview, not to separate lines. There are basicly 3 separations, which is: 1.x.x 2.x.x and 3.x.x, all separated with IP Routers.
    When the homeserver starts (with scan) it sends out every READ telegram 3 times.
    All IP Routers are set up with filtering enabled and the dummy for the homeserver is in ETS. The dummy objects are copied into the Group Objects.
    Everything works, it's just that the Homeserver sends out the READ telegrams 3x when restarting.
    Ja läuft bei mir so. Aber anstatt den Räumen habe ich da meine Geräte drin... Was ist gemeint mit Raum-A... Ein Gerät?
      It is just a 'room' with devices in it. The exact topology is like this:
      0.0.10 Homeserver
      1.0.0 IP-ROUTER1
      1.1.1 MDT Device1
      1.1.2 Tastsensor1
      1.1.3 Dimming Actor1
      1.2.1 MDT Device2
      1.2.2 Tastsensor2
      1.2.3 Dimming Actor2
      1.3.1 MDT Device3
      1.3.2 Tastsensor3
      1.3.3 Dimming Actor3
      1.4.1 MDT Device4
      1.4.2 Tastsensor4
      1.4.3 Dimming Actor4
      2.0.0 IP-ROUTER2
      2.1.1 MDT Device1
      2.1.2 Tastsensor1
      2.1.3 Dimming Actor1
      2.2.1 MDT Device2
      2.2.2 Tastsensor2
      2.2.3 Dimming Actor2
      2.3.1 MDT Device3
      2.3.2 Tastsensor3
      2.3.3 Dimming Actor3
      3.0.0 IP-ROUTER3
      3.1.1 MDT Device1
      3.1.2 Tastsensor1
      3.1.3 Dimming Actor1
      3.2.1 MDT Device2
      3.2.2 Tastsensor2
      3.2.3 Dimming Actor2
      3.3.1 MDT Device3
      3.3.2 Tastsensor3
      3.3.3 Dimming Actor3
      I have NO line couplers.
        What's the Problem?
          The only 'problem' is: When restarting the Homeserver, Why does the Homeserver requests all Group Objects 3x ?
          My project is very large and this is a HUGE amount of traffic on the bus.
          In another topic ( https://knx-user-forum.de/forum/%C3%...-homeserver-an ) I saw that someone had exactly the same problem (every telegram 3 times) and he was given a solution to set the IP router to 1.1.0 and Homeserver to 1.0.1.
          Since you are having the same setup as I have, do you also have this 'problem' when restarting the homeserver ?
            Wie hatte es Roman schon mal geschrieben?
            Wer die Topologie mit Füßen tritt dem tritt der Bus zurück.
            Es gibt in der ETS eine saubere Gebäudestruktursicht, da muss man keine unsaubere Topo bauen um eine Gebäudestruktur abzubilden. GA nach Orten zu strukturieren OK aber bei den PA ist das vollkommen überflüssig und müllt wie man sieht nur den Buss voll. Sowas kann bis auf saubere ACK auch noch mehr Probleme bereiten, gerade wenn man später echte Fehler durch Analyse des Telegrammverkehrs versucht zu finden.
            Telegramme durch drei Bereichskoppler die noch sauber filtern und melden, dann jeweils drei weitere Linien OHNE Linienkoppler, da kommt so ein System schon durcheinander.
            Ich vermute weil die Linienkoppler fehlen stimmen die Routingzähler nicht wenn sie am Gerät in der Linie ankommen. Das kann zu Wiederholungen führen.
            Zuviel Traffic wird nur weniger wenn auch wirklich filternde Koppler vorhanden sind oder eben ne Topo die zu der Anzahl Koppler passt.
            Zuletzt geändert von gbglace; 06.11.2019, 22:27.
              Zitat von Roeller Beitrag anzeigen
              Why does the Homeserver requests all Group [Objects] Addresses 3x ?
              Are there responses to the requests?
                Yes, The devices do send the answer 3 times.
