Fehlermeldung im Openhab.log
    ich bin am verzweifeln.
    habe folgende Things Datei
    Bridge knx:ip:bridge [
    type = "TUNNEL",
    ipAddress = "192.168.1.127",
    portNumber = 3671,
    localIp = "192.168.1.132",
    localSourceAddr = "15.15.13"
    Thing device d_BE8fachOG "d BE 8fach OG" [
    address = "1.1.15",
    fetch = false,
    pingInterval = 300,
    readInterval = 0
    Type switch : ch_BMFlurOG "ch BM Flur OG" [ga="1/1/141+<1/2/141"]
    Type switch : ch_SAFlurOG "ch SA Flur OG" [ga="1/1/181+<1/2/181"]
    die Bridge geht Online aber das Thing Device nicht und es kommt im Log folgende Meldung
    2020-11-23 20:01:39.281 [WARN ] [calimero.mgmt.TL 192.168.1.127:3671 ] - disconnected not gracefully (timeout)
    tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 15.15.13->1.1.15 L_Data.req, system priority hop count 6 repeat, tpdu 81
    at tuwien.auto.calimero.knxnetip.ClientConnection.doE xtraBlockingModes(ClientConnection.java:244) ~[?:?]
    at tuwien.auto.calimero.knxnetip.ConnectionBase.send( ConnectionBase.java:258) ~[?:?]
    at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send( KNXnetIPTunnel.java:177) ~[?:?]
    at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend( KNXNetworkLinkIP.java:264) ~[?:?]
    at tuwien.auto.calimero.link.AbstractLink.send(Abstra ctLink.java:332) ~[?:?]
    at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendReq uestWait(KNXNetworkLinkIP.java:243) ~[?:?]
    at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendD isconnect(TransportLayerImpl.java:627) ~[?:?]
    at tuwien.auto.calimero.mgmt.TransportLayerImpl.disco nnectIndicate(TransportLayerImpl.java:608) ~[?:?]
    at tuwien.auto.calimero.mgmt.TransportLayerImpl.disco nnect(TransportLayerImpl.java:342) ~[?:?]
    at tuwien.auto.calimero.mgmt.Destination.destroy(Dest ination.java:371) ~[?:?]
    at tuwien.auto.calimero.mgmt.Destination.close(Destin ation.java:383) ~[?:?]
    at tuwien.auto.calimero.mgmt.ManagementProceduresImpl .$closeResource(ManagementProceduresImpl.java:238) ~[?:?]
    at tuwien.auto.calimero.mgmt.ManagementProceduresImpl .isAddressOccupied(ManagementProceduresImpl.java:3 11) ~[?:?]
    at org.openhab.binding.knx.internal.client.AbstractKN XClient.isReachable(AbstractKNXClient.java:341) ~[?:?]
    at org.openhab.binding.knx.internal.handler.AbstractK NXThingHandler.pollDeviceStatus(AbstractKNXThingHa ndler.java:148) ~[?:?]
    at org.openhab.binding.knx.internal.handler.AbstractK NXThingHandler.lambda$1(AbstractKNXThingHandler.ja va:188) ~[?:?]
    at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) [?:1.8.0_272]
    at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308) [?:1.8.0_272]
    at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180) [?:1.8.0_272]
    at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294) [?:1.8.0_272]
    at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1149) [?:1.8.0_272]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:624) [?:1.8.0_272]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_272]
    was bedeutet das, wo hab ich da einen Fehler ?
    Servus, konkret kann ich nichts beitragen, aber deine Frage wäre im openHAB Unterforum sicher besser aufgehoben.
      Auf die schnelle entdecke ich auch nichts, aber evtl. hilft dir meine funktionierende Konfiguration: https://knx-user-forum.de/forum/%C3%...59#post1534359
      Wichtig: du hast auch wirklich eine Bridge bzw. Tunnel-Verbindung? Falls du einen Router hast, ist die Konfiguration anders.
