The linear pendant LED lights I am planning for my home office have 1-10V input on their LED drivers. DALI version is considerably more expensive and currently DALI is not used in the building, so adding DALI KNX gateway would add even more cost.
The only device that I found, which matches the requirement functionally, is Weinzierl 546 - https://www.voltus.de/hausautomation...haltaktor.html. However, that is DIN rail device and might be too large.
Maybe I have overlooked something and someone can suggest another KNX dimming actuator with 0/1-10V output, that can be mounted in suspended ceiling and would fit through an opening for 68mm cup?
