Lights not behaving as programmed...
    Hi guys
    I'm wondering if you would be able to assist me. I have programmed my KNX system and in one room am having an issue in getting all of the lights to dim at the same time when the switch it held on a long press. There are 3 rows of lights, but only the centre row will dim when the switch is on a long press. The other 2 x rows do not react. I can't figure out where I gone wrong to correct it.
    I have another switch at the end of the room, this is programmed just as a switch to turn all lights on or off in the same room (no dimming function). The switching side works fine.
    Dimming is not my friend at present.
    Any ideas?
    Ignore Post - all solved
    Thanks
