SpaceLynk as bus coupler and interface
    sorry for writing in English again.
    I have a project that contains two areas ( one line for each area), and that is two KNX areas are connected together by TCP/IP protocol (for specific reasons).
    additionally, I would like to use SpaceLynk LSS100200 with this project to can control all devices by mobile application. So my idea and worries are if it is possible use one IP-bus coupler (MTN6500-0103) for the first area, and SpaceLynk for the second area. instead of two ip bus coupler and SpaceLynk.
    So will SpaceLynk have ability to do the coupling between two areas (Via IP) and in the same time to control all devices that exists in both areas?
    (related to picture, like to use SpaceLynk instead of 2.1.0 ip bus coupler)
    This gallery has 1 photos.
    SpaceLynk can be used as an Line Coupler, you have to enable the IP Features in the Network settings. The KNX Communication must be set to TP UART.
    BUT when you use the SpaceLynk as an Line Coupler the Filte Table has to set Manualy ! And every change in the ETS has also to be done in the SpaceLynk.
    I Recomend an extra MTN6500-0103 for easier maintain reasons.
      I understand. do it manually is so annoying I think.
      Thank you for helping
