Hi All, I would like to configure ABB Taceto TB/12.7.1 switch as if short press will move down shutter totally and continues press will move it down as long as the button is pressed. I’m using JRA/s 8.230.2.1 Actuator. Best configuration?
KNX Standard is the other way, long press starts the full movement, short press stops it or makes a short movement. I don‘t know, if you can change it with ABB part. Once you get used to it, the KNX way ist pretty comfortable.
Regards Florian
