Once in a while we can read how KNX get password protected because network was open. Can someone explain how this happens - I thought KNX elements can only get programmed if someone presses "prog" button.Am I wrong?
KNX system hacks
Zitat von Klaus Gütter Beitrag anzeigenMost important: don't expose your IP interface on the public internet. Never..
If you want remote access, set up a VPN or use one of the availabe secure access modules (like Gira S1).
second: protect your wlan
third: make a separate sub-line for the outdoor area and block the access to the main line in the line coupler
and in general: read about knx secure
Thats not a security problem but a very important feature. You don't want to get on the roof everytime you want to change some parameters of your weather station or take a ladder to reach your presence detector.Zitat von ergo14 Beitrag anzeigenSo partial programming doesn't require physical press? That sounds like a security problem.
Its just my own house, there is only one device outside that is on the balcony - I'm not worried about physical third party doing any malicious manipulation. I just want to protect myself in case of network misconfiguration in my home just in case. I just wonder if i should spend the money for the module or setting BCU passwords will be enough. After all the installation is expensive.Zitat von Beleuchtfix Beitrag anzeigenMDT Security Module will prohibit programming, even if you have direct access to the TP line. It is password protected, but if you can physically remove it, you are out of luck.
Regards Florian
Yup, I will place it on the electrical board door so it never gets lostZitat von Beleuchtfix Beitrag anzeigenPassword is cheaper
ig you loose it, it is just like a system hack! So write it on some of the devices in the control board.
So this will secure the installation well enough so its not getting reprogrammed (I'm aware about listening and sending telegrams is still possible if configure network incorrectly).
Not really, it depends on the products.Zitat von ergo14 Beitrag anzeigenSo this will secure the installation well enough so its not getting reprogrammed
Full support of BCU passwords is optional.
A lot of products do not care about the set password and are still re-programmable even without password.
