Zitat von ergo14
KNX system hacks
Thats not the answer I got from the supportZitat von hjk Beitrag anzeigenWith SCN-SAFE.01 it is normally not possible to transfer the BCU Password to the device, because this writing is connection-oriented and the connection will be closed always.
I understand that you are MDT representative, correct? So what is the official stance on thisZitat von hjk Beitrag anzeigenWith SCN-SAFE.01 it is normally not possible to transfer the BCU Password to the device, because this writing is connection-oriented and the connection will be closed always.
You just have to consider the MDT Support as not competent enough to understand and answer such questions. But I'm pretty sure their next answer to that question will be correct.Zitat von ergo14 Beitrag anzeigenSo what is the official stance on this
I just went quickly through the manual. You can not only prevent unwanted programming, you can also perform supervision of all your KNX-Devices and monitor, if such device is no more working as intended by monitoring regular messages. You could even place switching actuators on dedicated part/segment of your KNX bus cabling as to force reset of the devices connected to such part/segment of your installation.
Basically you can implement security on several levels. First of all restrict access to port 3671 to local network devices only. If you cannot exclude lateral movement in your network, then you should consider additional measures as BCU-Password and/or Security Module (or change devices to KNX Secure). The prevention of lateral movement is a different topic.
Zitat von ergo14 Beitrag anzeigenGreat, can someone English speaking tell me if there is important information in the manual? There is no English version so I decided to not get the module for the time being
manual —> copy & paste to google translator
