Hi, I've bought PD11-KNX-FLAT-DX presence detectors for my home, I've placed two of these in the corridor. It turns out that they are picking up our cats moving on the stairs and trigger the lights. Is there any setting or potentiometr I can use to reduce the sensitivity on this thing? I've thought that most PIR sensors can be adjusted by a potentiometer.
I don‘t think that you will be successful, physics is not on your side. You are looking from ontop, so teh cats will always move through the sensitive sector.
Regards, Florian
