Hello,
I want to buy some CONSTALED 31346 Deep Tunable White LED spots, in my home I have KNX system with a DALI
gateway MDT SCN-DA641P.04S DaliControl IP Gateway PRO64 DALI-2.
I will have 4 spots connected on same circuit.
I want to ask if LUNATONE 89453836 DALI DT8 CW-WW PWM LED Dimmer CV, 12-28VDC 4 A would be a suitable high quality dimmer/driver for these spots?
Or LUNATONE 89453858-HS DALI DT8 - I understand this would allow for two separate circuits?
These drivers also require separate LED Power supply - am I correct?
Assuming I don't want to use separate power supplies (don't have space for them in fake ceilings) should use some other products instead?
Do I need any other equipment to start programming DALI apart from the gateway?
